411 Views, 1 Reply
Change Rep View of sub-assembly Pattern
Hello Community,
I need some Help...:)
I have an assembly (Lage_D) with a pattern of a subassembly (Teileraum) in it.
The pattern is created by a rule in the main assembly, the quanity of the pattern-objects is driven by the size of the subassembly.
If i manualy set the View rep to my specivic view, and the quantity of the pattern changes, the view rep of the new inserted subassemblys won t change!
Like to change the View Rep of each subassembly, in the pattern, by ilogic rule from the main assembly.
Found a lot of code dealing with this, but nothing fitts to my problem.(eg. "change viewrep in part ect." )
Tryed to change the code, but this dosent work properbly, my skills are to poor for this.
Pleas see the attached picture for more information
Thanks for help, will give kudos for every help!
Simon
Hello Community,
Found the Solution for my own, combined the code for a REP change issue.
Sadly i can t give my selfe a kudo !
CODE:
SyntaxEditor Code Snippet
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
Dim oMainAssyDef As AssemblyComponentDefinition
oMainAssyDef = asmDoc.ComponentDefinition
Dim oLODRep As DesignViewRepresentation
Dim doc As Document
For Each oOcc As ComponentOccurrence In oMainAssyDef.Occurrences
If oOcc.Suppressed Then Continue For
Try
If oOcc.DefinitionDocumentType _
= DocumentTypeEnum.kAssemblyDocumentObject Then
oOcc.SetDesignViewRepresentation("THE REP VIEW I NEED")
End If
Catch
End Try
Next
 THX
Vladimir.Ananyev
Found the solution here:
 http://forums.autodesk.com/t5/inventor-customization/lod-of-subassemblies/m-p/4382034#M45893
