^_^clovis^_^
367 Views, 0 Replies
Sketch 3d remove lines
Hello to all,
I'm writting a macro to remove entities (lines arcs..) in a 3D sketch that are not used in a sweep path, to clean the sketch3d up.
I was trying something like:
for each sketch3dEnt in sketch3dentities
 if sketch3dent not in oSweep.path then
   delete sketch3dEnt
but I can't like in Autocad use the handle to compare entities in a sketch3d.
How can I compare the entities in the sweep path against the 3D sketch to remove the un-used entities?
Thanks for any comments
