05-25-2016
05:49 AM
- Mute
- Permalink
- Report
05-25-2016
05:49 AM
I have come up with the following code which works fine but I hate the fact that I have to hard code the names of each parent bolt in component.replace command. See the code below.
Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument Dim oPattern As OccurrencePattern oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("BR STRING FASTENER SET") Dim oElement As OccurrencePatternElement oElements = oPattern.OccurrencePatternElements Dim i As Integer For i = 1 To oElements.Count Dim OCCS As OccurrencePatternElement OCCS = oElements(i).Components(1).OccurrencePatternElements(1) For Each OCCS In oElements Try Component.Replace("BR BOLT 1", "File name to replace with including path", False) Component.Replace("BR BOLT 2", "File name to replace with including path", False) Component.Replace("BR BOLT 3", "File name to replace with including path", False) Catch 'some code here
End Try Next Next InventorVb.DocumentUpdate()
As I understand, this code is replacing only the parent or master component. The rest of the occurrances are replaced or updated due to fact that they are the pattern of this master component. In this case the master components are 3 bolts.
Anyway it works!!
Cheers
