ekinsb
Thanks, I didn't know about those options within the command.  Unfortunately those are command specific and they aren't available through a setting or through the API.  The document setting that I showed in my last post can be set in your templates so new parts will inherit the setting but it affects a lot more than just the measure command.  There's also API functionality to set the document setting so you could have an add-in that sets it on-the-fly as new documents are created.  But you may not want to set the document setting since it does affect other things.
Brian Ekins
Mod the Machine blog
