in reply to: ekinsb
When modeling, the "Measure Distance" tool has a drop down called "Precision."
It looks like it defaults to 2 or 3 decimals. There is a choice that says "All Decimals." If you set it to show all decimals within an assembly or part, it will maintain that setting until that part or assembly is closed.
Opening a new part or assembly will not carry the All Decimals Precision, and requires you to set this choice again for every new part and/or assembly that you are working with.
I would like to run a piece of code on open, or just find some sort of global application setting that makes this All Decimals Precision stick around for every part or assembly that I open.
What you show under document settings ismaybe a start, but it only goes to 5 decimals places. Additionally, this setting (being a document level setting) doesn't "stick" when I open a new part or assembly.
The All Decimals Precision is there, as evidenced by the Measure Distance tool, I just want it to globally default to All Decimals.
