ekinsb
in reply to: nmunro
The RangeBox call is intended to be as fast as possible to be used as a quick way to eliminate or add an object to set of objects for further, more expensive processing.  I'm fairly certain that the range box for any spline based geometry is based on the control polygon of the spline so in most cases it will be larger than the actual curve or surface.  It would take me a while to dig into how Inventor is getting the size of the sheet metal part, but obviously it's doing a more expensive calculation to get a tight range box.
A way to get an accurate bounding box is to calculate your own based on a mesh representation of the body.  This may seem complicated but it's really not.  Below is a VBA implementation I just put together quickly to illustrate.
Public Sub t2()
    Dim doc As PartDocument
    Set doc = ThisDocument
    Dim xWidth As Double
    Dim yLength As Double
    doc.ObjectVisibility.AllWorkFeatures = False
    doc.ObjectVisibility.ConstructionSurfaces = False
    doc.ObjectVisibility.SketchDimensions = False
    doc.ObjectVisibility.Sketches = False
    doc.ObjectVisibility.Sketches3D = False
    Dim boundingBox As Box
    Set boundingBox = doc.ComponentDefinition.SurfaceBodies.Item(1).RangeBox
    xWidth = Round(Abs(boundingBox.MaxPoint.X - boundingBox.MinPoint.X), 3)
    yLength = Round(Abs(boundingBox.MaxPoint.Y - boundingBox.MinPoint.Y), 3)
    Debug.Print "X = " & xWidth
    Debug.Print "Y = " & yLength
    Set boundingBox = TightRangeBox(doc.ComponentDefinition.SurfaceBodies.Item(1))
    Debug.Print "Tight"
End Sub
Public Function TightRangeBox(Body As Inventor.SurfaceBody) As Inventor.Box
    ' Get the existing mesh of the highest resolution.
    Dim tolCount As Long
    Dim tols() As Double
    Call Body.GetExistingFacetTolerances(tolCount, tols)
    Dim i As Integer
    Dim bestTol As Double
    bestTol = tols(0)
    For i = 1 To tolCount - 1
        If tols(i) < bestTol Then
            bestTol = tols(i)
        End If
    Next
    Dim vertexCount As Long
    Dim facetCount As Long
    Dim vertexCoords() As Double
    Dim normalVectors() As Double
    Dim vertexIndices() As Long
    Call Body.GetExistingFacets(bestTol, vertexCount, facetCount, vertexCoords, normalVectors, vertexIndices)
    ' Loop through the vertices and build up the range box.
    Dim minX As Double
    Dim maxX As Double
    Dim minY As Double
    Dim maxY As Double
    Dim minZ As Double
    Dim maxZ As Double
    minX = vertexCoords(0)
    maxX = vertexCoords(0)
    minY = vertexCoords(1)
    maxY = vertexCoords(1)
    minZ = vertexCoords(2)
    maxZ = vertexCoords(2)
    For i = 1 To vertexCount - 1
        If vertexCoords(i * 3) < minX Then
            minX = vertexCoords(i * 3)
        End If
        If vertexCoords(i * 3) > maxX Then
            maxX = vertexCoords(i * 3)
        End If
        If vertexCoords(i * 3 + 1) < minY Then
            minY = vertexCoords(i * 3 + 1)
        End If
        If vertexCoords(i * 3 + 1) > maxY Then
            maxY = vertexCoords(i * 3 + 1)
        End If
        If vertexCoords(i * 3 + 2) < minZ Then
            minZ = vertexCoords(i * 3 + 2)
        End If
        If vertexCoords(i * 3 + 2) > maxZ Then
            maxZ = vertexCoords(i * 3 + 2)
        End If
    Next
    Dim newBox As Box
    Set newBox = ThisApplication.TransientGeometry.CreateBox()
    newBox.MinPoint = ThisApplication.TransientGeometry.CreatePoint(minX, minY, minZ)
    newBox.MaxPoint = ThisApplication.TransientGeometry.CreatePoint(maxX, maxY, maxZ)
    Set TightRangeBox = newBox
End Function
Brian Ekins
Mod the Machine blog
