05-09-2016
08:07 AM
- Mute
- Permalink
- Report
05-09-2016
08:07 AM
How are the points you are trying to export being created. Do you simply mean the end points of the edges of the parts (vertices) or are there actual points/workpoints in the model.
If your just trying to get all the part edges end points you'll need to do something like. (I didn't test the following just kind of generated it on the fly)
For i = 1 to oPartDef.SurfaceBodies.Count
For j = 1 to oPartDef.SurfaceBodies.Item(i).Edges.Count
oStartPoint = oPartDef.SurfaceBodies.Item(i).Edges.Item(j).StartVertex.Point
oStopPoint = oPartDef.SurfaceBodies.Item(i).Edges.Item(j).StopVertex.Point
'DO SOMETHING WITH THE POINTS HERE
'.... Exporting Points.....
Next
Next
We'll need a little more information, I believe, to help you along here if this isn't what you are trying to do.
An image of your model with the points your working with might be helpful if its not easily explained.
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
