Jef_E
281 Views, 1 Reply
AddIn get parameter from assembly constraint object
Hi!
This is probably not so hard to do.. But i'm failing to do it..
I have a tool that creates a certain set of assembly constraints. Now I want to get the parameter that drives the constraint value. But how do you access it?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
