efhara
287 Views, 1 Reply
Export all vertices from Part Document without selection
Hello everyone!
Please Help!
I have a Part Document that's a result of a subtraction (with kDerivedSubtractAll) in a DerivedAssemblyDefinition.
I want to export the coordinates of the vertices/points included in the Part geometry to an Excel File without selecting them. So, I need either an automatic selection of all part-vertices and then export of their coordinates or an automatic recognition of the part's vertices created as a result of the Subtraction.
I have been trying to use the "workpoints" with DocDef.workpoints so to have all points of part as an output  but all I get exported to the Excel Document is just one point with zero values (probably the ucs-origin) so I assume that the workpoints do not represent all points/vertices in an activedocument.
Do you have any suggestions???
Thanks in advance!!
