- Mute
- Permalink
- Report
Saving Metadata in Document File without changing DbRevisionId or RevisionId
Morning,
Last week I posted ... "We are working on a project to generate inventor documents from master "templates" parametrically (similar to iparts) using both iLogic and the api. I am looking for some technique/method to fully qualify if "any edits" have been made to the document after it was generated."
At that time I thinking of trying to calc a checksum and looking for some method to embedded the checksum in the doc file. Adam Nagy suggested using the document RevisionId and DatabaseRevisionId to qualify if any edits had been made. Turns ou that works quite nicely.
However I am still evaluationg the best method to embed these values (and also a larger serailized config file) into the file.
Did find several articles related to "Save extra data in Inventor file" by Xiaodong Liang on http://adndevblog.typepad.com/manufacturing/2013/03/save-extra-data-in-inventor-file-1.html
He details three methods available.. 1. iProperties 2. Attribute 3. IStorage & IStream
Did a bit of testing trying each of these techniques to save my metadata.
In my test it seems that using Attributes or iStorage requires a full document save.. which changes the DatabaseRevisionId and RevisionId. Which for my purposes is not ideal.
However did find when using the Custom Property Set and Apprentice FlushToFile to push the properties to the document file the DbRevisionId and RevisionId are not changed. For my purpsose this seems ideal.. but would like to confirm my assumptions before pressing on.
Could anyone confirm that if using Apprentiice PropertySet.FlushToFile with a Custom PropertySet will "never"change the DbRevisionId and RevisionId of the document?
My second questions is "how much data can each property in the property set contain"?
Reason for second question is I am considering using this propertyset to also store a larger set of data.. serialized configuration data for the app. Did a quick test and a singe property appearred to accept 100k of data.. but 1 mb it fell over. Possibly I can break the serialize string into chunks to store it in the property sets.
I would think that iStorage/Attributes would be really designed to store larger sets of data... But if Custom PropertySets don't effect RevisionId then I think it would be my first choice.
