Jef_E
1443 Views, 5 Replies
AddIn event on document change
Hi!
I'm writing an addin that works with iProperties of the active document or the selected document. But I can't find the right event to trigger my code.
What I have now is 2 events,
first when the user selects an item (in assembly)  this works fine for me.
' Add event handler for user selected object event
m_UserInputEvent = m_inventorApplication.CommandManager.UserInputEvents
AddHandler m_UserInputEvent.OnSelect AddressOf OnDocumentChangeEvent
But I want also an event when the user changes document open or switches active document on the bottom with tabs.
' Add event handler for OnDocumentChange event.
m_AppEvents = m_inventorApplication.ApplicationEvents
AddHandler m_AppEvents.OnActivateDocument, AddressOf OnDocumentChangeEvent
This second event fires more than I like, on open document 2x and on other unwanted moments. What event can I use for this?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
