Jef_E
1439 Views, 5 Replies
AddIn event on document change
Hi!
I'm writing an addin that works with iProperties of the active document or the selected document. But I can't find the right event to trigger my code.
What I have now is 2 events,
first when the user selects an item (in assembly)  this works fine for me.
' Add event handler for user selected object event
m_UserInputEvent = m_inventorApplication.CommandManager.UserInputEvents
AddHandler m_UserInputEvent.OnSelect AddressOf OnDocumentChangeEvent
But I want also an event when the user changes document open or switches active document on the bottom with tabs.
' Add event handler for OnDocumentChange event.
m_AppEvents = m_inventorApplication.ApplicationEvents
AddHandler m_AppEvents.OnActivateDocument, AddressOf OnDocumentChangeEvent
This second event fires more than I like, on open document 2x and on other unwanted moments. What event can I use for this?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
in reply to: Jef_E
this is how I add event triggers to the standardAddInServer:
at the start of the namespace i add the line
 Private WithEvents oAppEvents As ApplicationEvents
as shown:
 Public Class StandardAddInServer
        Implements Inventor.ApplicationAddInServer
        'Application events object
This means I can them select oAppEvents from the left dropdown above yor code window, and from the right one you have a full set of event triggers ready. to use.
I Can then choose OnActivateDocument and I get the empty sub as below:
      Private Sub oAppEvents_OnActivateDocument(ByVal DocumentObject As Inventor._Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles oAppEvents.OnActivateDocument
        End Sub
As you might've guessed, any code in here will fire upon a docuement being made active, eg switching between two docs.
but this trigger, as with all triggers will fire twice, once before the event and once after it. this is why you're  seeing it happen twice,
To prevent this you need to tell the sub when you want it to fire, either before or after the event like this:
            'fire after document is made active
            If BeforeOrAfter = EventTimingEnum.kAfter Then
            End If
            'fire before document is made active
            If BeforeOrAfter = EventTimingEnum.kBefore Then
            End If
        End Sub
hope this helps.
hello,
I have tried this exactly as in your example, but for some reason it does not fire the sub.
what could be the cause?
Thank you!
marcin_otręba
You trying to adress two different events to one sub?
it will not work this way.
@SutherNe Solution is almost comlete only one small thing that you need set oAppevents
best way to add it in addin activate method :
g_inventorApplication = addInSiteObject.Application
oAppevents= g_inventorApplication.ApplicationEvents()
dont forget to declare g_inventorApplication like:
Public g_inventorApplication As Inventor.Application
or use your own object for inventor...
in reply to: marcin_otręba
Thanks, that did the trick!
