wayne.brill
in reply to: karthur1
Hi Kirk,
Thanks for sending the assembly. Here is the iLogic rule that works for me. (no error about missing occurrence) Not exactly sure this is what you want.
oLength = InputBox("Enter the length change (+ or -)in inches.", "iLogic", "0.25")
Dim oAsmDoc as Inventor.AssemblyDocument
oAsmDoc = ThisDoc.Document
Dim comp As Inventor.ComponentOccurrence
		'Lista = ""
		For Each oOcc In ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.AllLeafOccurrences
			'Lista=oOcc.Name
			'WB commented above, it helps me to have a variable name that indicates what the varible is
			occName = oOcc.Name
			'WB added - just wanted to see the names of the occurrences and exit
			'MsgBox("occName = " & occName)
		'Next
		'Return
	        'WB commented, not sure what this for loop was supposed to do
			'For Each comp In oAsmDoc.ComponentDefinition.Occurrences
		        'WB commented
				'rowName = iPart.RowName(comp.Name)
				rowName = iPart.RowName(occName)
				RowValue = iPart.CurrentRowValue("Cutlength")
				StockNoStringValue = iPart.CurrentRowStringValue("Stock Number")
				NewLength = RowValue+oLength
				MemberStringValue = StockNoStringValue & "-" & NewLength
				'MsgBox("New Size==> " & MemberStringValue & " Current RowName==> " & rowname & " New Length ==> "& NewLength)
				'MsgBox("Size==> " & MemberStringValue & " RowName==> " & iPart.RowName(comp.Name) & " New Length ==> "& NewLength)
				MemberStringValue = iPart.CurrentRowStringValue("Stock Number") & "-" & iPart.CurrentRowValue("Cutlength") + oLength
				'iPart.ChangeRow(Lista, MemberStringValue)
				MsgBox("occName = " & occName & " Changing to " & MemberStringValue)
				iPart.ChangeRow(occName, MemberStringValue)
				'iPart.ChangeRow("iComponentName:1", "RowMemberName")
				'i = iPart.FindRow(comp.Name, "Member", "=", MemberStringValue)
	 		Next
   			If i < 0 Then
       			MessageBox.Show("Some problem occurred", "iLogic")
    		Else
        		'MessageBox.Show("iPart set to row: " & MemberStringValue , "Change ALL members iLogic")
    		End If
		'WB commented
		'Next
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
