I’m guessing that no one can help on this problem? We found a workaround that kind of works but not the way that I would like. We have code in the drawing that will look inside the part and if that extrusion is suppressed then it will suppress the detail view. The problem with this is that when you change the name of the detail view the code doesn’t work anymore. It would be a lot nicer if we could just suppress detached detail views with a little code. I would appreciate any help you might be able to give.
