- Mute
- Permalink
- Report
ILogic rule to suppress detail views in drawing
Is there a rule that can suppress detail views in drawing if it cannot attach to the view? We have a template that will make the part, run calculations, and scale each view when opening the drawing but it would be helpful if we could suppress the views that are not needed. Thank you for any help you might be able to give.
- Mute
- Permalink
- Report
Hello jddickson,
I will be asking the forum moderator to move this post into the Inventor Customization forum where these questions are better suited for ILogic questions.
Don
- Mute
- Permalink
- Report
I’m guessing that no one can help on this problem? We found a workaround that kind of works but not the way that I would like. We have code in the drawing that will look inside the part and if that extrusion is suppressed then it will suppress the detail view. The problem with this is that when you change the name of the detail view the code doesn’t work anymore. It would be a lot nicer if we could just suppress detached detail views with a little code. I would appreciate any help you might be able to give.
- Mute
- Permalink
- Report
You could try examining the corresponding browser node icon state. Or examing the API/object model and come up with some other test, and try that out.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
