04-07-2016
09:22 AM
- Mute
- Permalink
- Report
04-07-2016
09:22 AM
PBALL,
I've seen this come about a few other times where during comparisons some tiny decimal portion is attached to the end of a measurement (think .1046000000001)
As a result numerical equality comparisions fail. I've seen a few ways to handle this by adapting for a given tolerance threshold, such as the EqualWithinTolerance command.
In the case of a Select Case operation (no pun intended) I would use a range to define each value, though we all know you shouldn't have to do this.
Here is a sample of what I would employ. It doesn't require a very large range, just enough to nullify the tiny discrepency.
Case 0.10459 To .10461
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
