627 Views, 2 Replies
iLogic get partnumbers of certain parts, create a running list in assembly iprop
Hello Guys,
i have a certain assembly with 4-5 Parts and i want to fill the PartNumber of the Assembly with a running list of the ipts Part Numbers (Part1, Part2, Part3). Separated with commas or semicolon.
And how can i define Part 1 with a certain filename form, i.e.
If docFile.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "*-*-*" Then
Part1 = docFile.PropertySets.Item("Design...
My Code so far, i hope you can help me out
SyntaxEditor Code Snippet
Dim openDoc As AssemblyDocument
openDoc = ThisApplication.ActiveDocument
Dim customPropSet As PropertySet
Dim Parts As DocumentsEnumerator
Parts = openDoc.AllReferencedDocuments
Dim Part As Document
Dim NameList As New ArrayList
'Iterate through the occurrences And collect the name.
For Each docFile In openDoc.AllReferencedDocuments
oPartNumber = (docFile.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value)
    NameList.add(oPartNumber)
Next
If openDoc.DocumentType = 12291 Then
        If docFile.DocumentType = 12291 Then
                    Try
                    If Left(System.IO.Path.GetFileNameWithoutExtension(docFile.FullFileName),7) = "Schraub" Then
                    docFile.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = NameList
                    Else
                    End If
                    Catch
                    End Try
        End If
    Next
Else
End If
