- Mute
- Permalink
- Report
I have a ilogic code that changes all my memebers lengths by a specific amount. The code is here in this thread. The line that changes the member is
i = iPart.FindRow(comp.Name, "Length", "=", oLength)
The problem that I have is that this iPart has a couple thousand rows (not exactly sure how many... I just know it a lot). When the code runs, it will take over 6 minutes to change out two parts. The CPU is running at 25-26% during this time, so its working hard at it. If I manually change the components, it will take the ipart table about 45 seconds to come up so I can change the part.
I take it that the code is actually running thru the table until it finds a match. Since the table is rather large, it takes awhile to scan thru it.
Is there a faster way to set the member?
Kirk
- Mute
- Permalink
- Report
Could you post the code you are really using? Or is the accepted as solution the real code?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
- Mute
- Permalink
- Report
I don't have the exact code with me at the moment. It is very similar to the accepted solution. The code gathers some information about the current row before it gets to the for/next with the "i = iPart.FindRow(comp.Name, "Length", "=", oLength) " line.
I can post the entire code later this afternoon.
Kirk
- Mute
- Permalink
- Report
@karthur1 wrote:I don't have the exact code with me at the moment. It is very similar to the accepted solution. The code gathers some information about the current row before it gets to the for/next with the "i = iPart.FindRow(comp.Name, "Length", "=", oLength) " line.
Kirk
That would be helpfull.
Inventor 2014 SP2
- Mute
- Permalink
- Report
Below is the entire code. I just looked at the ipart and it has 3,683 rows.
Kirk
oLength = InputBox("Enter the length change (+ or -)in inches.", "iLogic", "0.25")
Dim oAsmDoc as Inventor.AssemblyDocument
oAsmDoc = ThisDoc.Document
Dim comp As Inventor.ComponentOccurrence
For Each comp In oAsmDoc.ComponentDefinition.Occurrences
rowName = iPart.RowName(comp.Name)
RowValue=iPart.CurrentRowValue("Cutlength")
StockNoStringValue=iPart.CurrentRowStringValue("Stock Number")
NewLength=RowValue+oLength
MemberStringValue=StockNoStringValue & "-" & NewLength
i = iPart.FindRow(comp.Name, "Member", "=", MemberStringValue)
If i < 0 Then
MessageBox.Show("Some problem occurred", "iLogic")
Else
'MessageBox.Show("iPart set to row: " & MemberStringValue , "Change ALL members iLogic")
End If
Next
- Mute
- Permalink
- Report
Maybe, you can save the row into a variable. And then refer to that variable instead of looking into the table's current row. Don't know if it would do much. But maybe a little.
Dim iPartRow As iPartTableRow
What I don't quite understand, is this line. Does it also activate the new found row?
Maybe you can shorten you code a little. The rowName varaible is unused? you should delete or comment it out.
This is you loop;
RowValue = iPart.CurrentRowValue("Cutlength")
StockNoStringValue = iPart.CurrentRowStringValue("Stock Number")
NewLength = RowValue + oLength
MemberStringValue = StockNoStringValue & "-" & NewLength
If i < 0 Then
Else
End If
NextIn short it could also be this, same effect ( haven't tested it ).
Also I have no idea if this has a real impact on the speed. But you could give it a shot. (let me know the result, i'm just learning to code efficiently myself).
MemberStringValue = iPart.CurrentRowStringValue("Stock Number") & "-" & iPart.CurrentRowValue("Cutlength") + oLength
If i < 0 Then
Else
End If
NextI also have a question about the IF ELSE END IF statement on the end.
i = the row number and when there is a error, it goes to -1 or how does this check work? I don't have a clue ![]()
If i < 0 Then
Else
End IfHope you find this post helpfull.
Inventor 2014 SP2
- Mute
- Permalink
- Report
Jeff,
From the help in the iLogic, the FindRow command will find the row that mets the condition and change to that row if found.... if not, it sets i=-1. So the error check at the end is so that if i=-1, it will give a message that something went wrong.... otherwise it assumes it completed successfully and continues.
If I comment out the line "rowName = iPart.RowName(comp.Name)".... I then get the error of:
"iPart.CurrentRowValue("Cutlength"): This function was called without a previous call to iPart.ChangeRow or iPart.FindRow.
Maybe there is a way to avoid this, but I am not sure.
Kirk
- Mute
- Permalink
- Report
I had an idea of rather than searching the table for the correct value, I would just tell it what value to set it to. It seems that the command
"iPart.ChangeRow("iComponentName:1", "RowMemberName") " would do exactly what I need. The code would work something like this.
Start with the first iPart.. Get its Component Name and length. Add the increment to the length.... then change this with the "iPart.ChangeRow " command. Go to the next part in the assembly and do the same thing. Continue until all the parts are changed.
I can get this code to work for the first part, but then it errors out when it gets to the second part. The "Lista" variable is the component browser name.
I am probably going about this all wrong. Any Suggestions?
Kirk
SyntaxEditor Code Snippet
oLength = InputBox("Enter the length change (+ or -)in inches.", "iLogic", "0.25") Dim oAsmDoc as Inventor.AssemblyDocument oAsmDoc = ThisDoc.Document Dim comp As Inventor.ComponentOccurrence Lista = "" For Each oOcc In ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.AllLeafOccurrences Lista=oOcc.Name MsgBox(Lista) For Each comp In oAsmDoc.ComponentDefinition.Occurrences rowName = iPart.RowName(comp.Name) RowValue=iPart.CurrentRowValue("Cutlength") StockNoStringValue=iPart.CurrentRowStringValue("Stock Number") NewLength=RowValue+oLength MemberStringValue=StockNoStringValue & "-" & NewLength MsgBox("New Size==> " & MemberStringValue & " Current RowName==> " & rowname & " New Length ==> "& NewLength) 'MsgBox("Size==> " & MemberStringValue & " RowName==> " & iPart.RowName(comp.Name) & " New Length ==> "& NewLength) 'MemberStringValue = iPart.CurrentRowStringValue("Stock Number") & "-" & iPart.CurrentRowValue("Cutlength") + oLength iPart.ChangeRow(Lista, MemberStringValue) 'iPart.ChangeRow("iComponentName:1", "RowMemberName") 'i = iPart.FindRow(comp.Name, "Member", "=", MemberStringValue) Next If i < 0 Then MessageBox.Show("Some problem occurred", "iLogic") Else 'MessageBox.Show("iPart set to row: " & MemberStringValue , "Change ALL members iLogic") End If Next
- Mute
- Permalink
- Report
Hello Kirk,
I am not sure what is causing the error just looking at the code. Can you upload a small assembly that will allow me to recreate the error? If you want to keep it private you can send it to wayne.brill@autodesk.com
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Hi Kirk,
Thanks for sending the assembly. Here is the iLogic rule that works for me. (no error about missing occurrence) Not exactly sure this is what you want.
'Lista = ""
'Lista=oOcc.Name
'WB commented above, it helps me to have a variable name that indicates what the varible is
occName = oOcc.Name
'WB added - just wanted to see the names of the occurrences and exit
'MsgBox("occName = " & occName)
'Next
'Return
'WB commented, not sure what this for loop was supposed to do
'For Each comp In oAsmDoc.ComponentDefinition.Occurrences
'WB commented
'rowName = iPart.RowName(comp.Name)
rowName = iPart.RowName(occName)
NewLength = RowValue+oLength
'MsgBox("New Size==> " & MemberStringValue & " Current RowName==> " & rowname & " New Length ==> "& NewLength)
'iPart.ChangeRow(Lista, MemberStringValue)
MsgBox("occName = " & occName & " Changing to " & MemberStringValue)
iPart.ChangeRow(occName, MemberStringValue)
Next
If i < 0 Then
Else
End If
'WB commented
'Next
Wayne
Wayne Brill
- Mute
- Permalink
- Report
Wayne,
Many thinks.... That is slick. It does exactly what I was trying to do. The for/next loop that you commented on was used to gather the information about each part in the assembly. It would then search the ipart table and add the increment to the member.
I will try this later with the ipart member that is over 3,000 members long. I think it will be faster..... will let you know how it goes.
Thanks again,
Kirk
- Mute
- Permalink
- Report
Wayne,
Normally when I am changing out these members, it will take about 45secs for the table to be displayed so I can select a different member. I have to go thru each part and change them and it gets frustrating after awhile.
I tried this on my "working" ipart with over 3,000 rows in the table. Attached is a video of this code working. It actually takes less than 20 secs to change 4 members. ![]()
Thanks again,
Kirk
- Mute
- Permalink
- Report
I can't see a video. Glad it's sorted for you!
Inventor 2014 SP2
