409 Views, 1 Reply
Inventor - Style & Standard Editor
I am trying so set up my standard inventor drawing style and wanted to know how you edit the standard hole note??
Also I was wondering if when you have a detail view, the arrow which points to the master view can be changed for example fom just A to 'A'
If anyone knows the answer it would be a massive help!
NSBowser
Emmadudman,
Just for your reference, these questions are not Inventor Customization topics (Automation and Programming) but are rather General Inventor questions. For future questions, ensure you are posting your questions in the most appropriate forum to ensure it gets the visibility it needs.
Regardless, the information below should help you out.
Here is information on Editing the Hole Note Style. If you don't know how styles work in Inventor you will want to read up on those as well, since they are a common cause for confusion and mistakes for beginners.
         Hole Note Style Information
Here is information on editing your view label. You'll need to modify the standard View preferences in the Styles and standards editor.
         View Preferences Information
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
