in reply to: adam.nagy
I KNEW IT! This is fantastic!! I knew there had to be a way. I almost just accepted that I would have to type in material properties for every single little part. This saves DAYS of typing. I can't thank you enough! I will be using this code on every single one of our product models! One thing however, since there are suppressed parts within a sub-assembly, the code iLogicVb.RunRule("Forum Test") had to be added to a separate rule within the sub-assembly so that the unsuppressed part would change its material. Other than that, this worked perfect!!Thanks again! Thanks Sandro
