rhasell
868 Views, 3 Replies
iLogic Printing - another one.
Hi
I have been trying to create a printing rule, I print half size (Scale 0.5) to hard copy printer and full size (Scale 1:1) to PDF.
At this stage I am still with the Hard copy printer and I am unable to set the custom scale.
I have used existing code found on the forum, and have been trying to adjust it to suit my requirements.
As you can see I have tried various options of changing the scale, but regardless it still prints to fit. (I commented out the scale to fit)
Hopefully it's just a syntax error?
Existing code:
Dim oDrawDoc As Document
oDrawDoc = ThisApplication.ActiveDocument
 Dim oPrintMgr As PrintManager
 oPrintMgr = oDrawDoc.PrintManager
 'specify your printer name
 oPrintMgr.Printer = "Canon iR2520 UFRII LT"
oPrintMgr.ColorMode = kPrintDefaultColorMode
oPrintMgr.Orientation = kLandscapeOrientation
oPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeA3
oPrintMgr.Scalemode = kCustomScale
oPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale
''Testing for scale
'oPrintMgr.Scale = 0.5
'.Scale = 0.5
'oPrintMgr.ScaleMode = PrintScaleModeEnum.scale=0.5
oPrintMgr.SubmitPrint
Thanks guys.
Hopefully the PDF print is easier, as its a 1:1 print.
Reg
2025.2
rhasell
in reply to: rhasell
Hi all
Solved, if it helps someone, hit the Kudos button.
oPrintMgr.Scalemode = 13827 'Custom Scale
oPrintMgr.ScaleMode = "0.5"
The PDF was easy as well.
 oPrintMgr.Printer = "PrimoPDF"
oPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeA1
oPrintMgr.Scalemode = 13825 'Full Scale print @1:1
Reg
2025.2
rhasell
Hi
It appears I was a little ahead of myself there, After restarting inventor, the Printer scale went back to "1"
It still changed to custom scale, but just set the scale value to "1" and not "0.5"
So I guess it s still not working?
Reg
2025.2
rhasell
Seriously......
A simple sytax error:
All fixed now.
Reg
2025.2
