adam.nagy
In the sample assembly you attached there were parts also directly under the main assembly - not only under the subassembly.
So you would still need to set the material at the top level assembly as well.
There could be multiple ways of achieving what you need, but you know best how the assemblies and parts will be used, which parts' material should be controlled from where, etc.
Also, are the parts only used from a single assembly? Because once you set the material for them it will be the same in all the assemblies they are being used in. I'm assuming for each assembly you create you copy those parts into the assembly's folder, or something like that?
Adam Nagy
Autodesk Platform Services
