Curtis_Waguespack
in reply to: rfink
Hi rfink,
Assuming the rule with the error is an internal rule and not an External rule, I think you can use something like this to suppress a rule of given name, as you edit the document. Make sure to use ActiveEditDocument (rather than ActiveDoucment).
Auto = iLogicVb.Automation
Dim iLogicAuto As Object
iLogicAuto = Auto
Dim oDoc As Document
oDoc = ThisApplication.ActiveEditDocument
'get collection of rules
Dim ruleName As String
Dim rules As Object
rules = iLogicAuto.rules(oDoc)
'make sure there are rules in the file
If Not (rules Is Nothing) Then
	For Each rule In rules
	If rule.Name = "MyRule" Then
		'suppress rule
		iLogicAuto.GetRule(oDoc, rule.Name).IsActive = False
	End If
	Next
Else
End If
Or use this to delete the rule:
iLogicAuto = Auto
Dim rules As Object
		'delete rule
		iLogicAuto.DeleteRule(oDoc, rule.Name)
	End If
	Next
Else
End If
I hope this helps.
Curtis
