rjay75
3291 Views, 10 Replies
Visual Studio Versions and Inventor Interop
Has anyone else run into this issue? I'm in the process of finally updating my Addins for 2016/2017 and thought I would take the opportunity to also move my projects to Visual Studio 2015 so I could take advantage of some of the new C# 6 language features.
As seen in this post (parameter.get_Units() vs. parameter.Units) the Inventor interop doesn't always line up nicely with C#. Using Visual Studio 2015 the same issue still exists. However even though the project compiles fine it throws a member not found exception when trying to resolve parameter.get_Units() method. The CommandType enum also sometimes shows an error in the editor but compiles ok. Reverted back to VS 2013 and the same code works fine. I know the VS uses the new Roslyn C# compiler so I'm wondering if it's something to do with that or if it's something with my .NET installation.
