Owner2229
Hi, you have to run it once, then go to parameters (or do it using another rule) and select an value for the "SIZE" parameter. Then run this rule again.
I have added parameter check so you don't need to care if the parameter is created or not. The parameter "MODEL" is not needed as all the values are now stored in the "oMyValues" object.
Sub Main()
    CheckParam("SIZE")
MultiValue.SetList("SIZE", "SIZE-AA", "SIZE-BB", "SIZE-CC") Dim Row As Integer Dim oMyValues(9, 5) As Object ' Set the range for values (9 rows, 5 columns) GoExcel.Open("filename.xls", "Sheet1") Row = 1 For j = 3 To 5 ' Set the rows for AA... values GetValues(oMyValues, Row, j) Row = Row + 1 Next For j = 8 To 10 ' Set the rows for BB... values GetValues(oMyValues, Row, j) Row = Row + 1 Next For j = 13 To 15 ' Set the rows for CC... values GetValues(oMyValues, Row, j) Row = Row + 1 Next GoExcel.Close Dim oModel As String oModel = Parameter("SIZE") Dim MyArrayList As New ArrayList For i = 1 To UBound(oMyValues, 1) If oMyValues(i, 1) = oModel Then MyArrayList.Add(oMyValues(i, 2)) MyArrayList.Add(oMyValues(i, 3)) MyArrayList.Add(oMyValues(i, 4)) MyArrayList.Add(oMyValues(i, 5)) End If Next
CheckParam("SIZE_VALUES") MultiValue.List("SIZE_VALUES") = MyArrayList End Sub Private Sub GetValues(oMyValues As Object, Row As Integer, j As Integer) oMyValues(Row, 1) = GoExcel.CellValue("A" & j) oMyValues(Row, 2) = GoExcel.CellValue("B" & j) oMyValues(Row, 3) = GoExcel.CellValue("C" & j) oMyValues(Row, 4) = GoExcel.CellValue("D" & j) oMyValues(Row, 5) = GoExcel.CellValue("E" & j) End Sub Private Sub CheckParam(oParaName As String) oParameters = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters Try Parameter(oParaName) = Parameter(oParaName) Catch oParameter = oParameters.AddByValue(oParaName, "", UnitsTypeEnum.kTextUnits) End Try End Sub
Here below is the rule to pick one of the "SIZE" parameter values. Use the number to pick (first/second/...) value from the parameter list.
Try
    Parameter("SIZE") = Parameter("SIZE")
Parameter("SIZE") = MultiValue.List("SIZE").Item(1)
Catch MsgBox("The parameter 'SIZE' doesn't exist") End Try
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
