02-10-2016
06:22 AM
- Mute
- Permalink
- Report
02-10-2016
06:22 AM
Hi, as I see now I had some errors in the code. This one below should be working. You muss have the folowing parameters in model:
SIZE
SIZE_VALUES
Sub Main()
MultiValue.SetList("SIZE", "SIZE-AA", "SIZE-BB", "SIZE-CC")
Dim Row As Integer
Dim oMyValues(9, 5) As Object ' Set the range for values (9 rows, 5 columns)
GoExcel.Open("filename.xls", "Sheet1")
Row = 1
For j = 3 To 5 ' Set the rows for AA... values
GetValues(oMyValues, Row, j)
Row = Row + 1
Next
For j = 8 To 10 ' Set the rows for BB... values
Row = Row + 1
Next
For j = 13 To 15 ' Set the rows for CC... values
Row = Row + 1
Next
GoExcel.Close
Dim oModel As String
oModel = Parameter("SIZE")
Dim MyArrayList As New ArrayList
For i = 1 To UBound(oMyValues, 1)
If oMyValues(i, 1) = oModel Then
MyArrayList.Add(oMyValues(i, 2))
MyArrayList.Add(oMyValues(i, 3))
MyArrayList.Add(oMyValues(i, 4))
MyArrayList.Add(oMyValues(i, 5))
End If
Next
MultiValue.List("SIZE_VALUES") = MyArrayList
End Sub
Private Sub GetValues(oMyValues As Object, Row As Integer, j As Integer)
oMyValues(Row, 1) = GoExcel.CellValue("A" & j)
oMyValues(Row, 2) = GoExcel.CellValue("B" & j)
oMyValues(Row, 3) = GoExcel.CellValue("C" & j)
oMyValues(Row, 4) = GoExcel.CellValue("D" & j)
oMyValues(Row, 5) = GoExcel.CellValue("E" & j)
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Mike
