02-09-2016
02:53 AM
- Mute
- Permalink
- Report
02-09-2016
02:53 AM
Here is version that uses SelectSet.
It WORKS on parts in subassemblies. I tested it.
Sub Main()
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim comps As SelectSet
Dim comp As ComponentOccurrence
comps = oDoc.SelectSet
'If there are selected components we can do something, otherwise we're done
If comps.count = 0 Then Exit Sub
Dim aDoc As DocumentsEnumerator
aDoc = oDoc.AllReferencedDocuments
Dim iDoc As Document
Dim cName As String
Dim cTS As String
Dim sTS As String
Dim FNP As Long
Dim cFNP As Long
Dim docFN As String
For Each iDoc In aDoc
sTS = iDoc.FullFileName
FNP = InStrRev(sTS, "\", - 1)
docFN = Mid(sTS, FNP + 1, Len(sTS) - FNP)
For Each comp In comps
cTS = comp.Name
cFNP = InStrRev(cTS, ":", - 1)
cName = Left(cTS, cFNP - 1)
If cName = Left(docFN, Len(docFN)-4) Then
'Set iProperty in each of the selected parts in assembly
iProperties.Value(docFN, "Custom", "Mark") = "this part is now marked"
End If
Next
Next
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Mike
