02-08-2016
11:19 PM
- Mute
- Permalink
- Report
02-08-2016
11:19 PM
Hi, try this and let me know if it does what you want.
It will ask you to select part(s). Select as mayn as you want and end the selection with "Esc".
Sub Main()
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim comps As ObjectCollection
Dim comp As ComponentOccurrence
oDoc.SelectSet.Clear
comps = ThisApplication.TransientObjects.CreateObjectCollection
While True
comp = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kAssemblyLeafOccurrenceFilter,
"Select Part(s)")
'If nothing gets selected then we're done
If IsNothing(comp) Then Exit While
comps.Add(comp)
End While
'If there are selected components we can do something, otherwise we're done
If comps.count = 0 Then Exit Sub
Dim aDoc As DocumentsEnumerator
aDoc = oDoc.AllReferencedDocuments
Dim iDoc As Document
Dim cName As String
Dim cTS As String
Dim sTS As String
Dim FNP As Long
Dim cFNP As Long
Dim docFN As String
For Each iDoc In aDoc
sTS = iDoc.FullFileName
FNP = InStrRev(sTS, "\", - 1)
docFN = Mid(sTS, FNP + 1, Len(sTS) - FNP)
For Each comp In comps
cTS = comp.Name
cFNP = InStrRev(cTS, ":", - 1)
cName = Left(cTS, cFNP - 1)
If cName = Left(docFN, Len(docFN)-4) Then
'Set iProperty in each of the selected parts in assembly
iProperties.Value(docFN, "Custom", "Mark") = "this part is now marked"
End If
Next
Next
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Mike
