Jef_E
967 Views, 1 Reply
API - Get drawingcurve circle radius
I'm trying to create a small tool that adds orienations on a drawing file. In order to do so, the user must select a circle and then the program will add 0°, 90° 180° 270° text items on them.
The problem:
After I obtained the DrawingCurve I get the center point of the cirlce, but I also need the radius.
I don't know how I can get this information?
My code:
Spoiler
    Private Sub Orientation_Click(sender As Object, e As EventArgs) Handles Orientation.Click
        ' Reference the active document
        Dim oDoc As Inventor.Document
        oDoc = oInvApp.ActiveDocument
        ' Check document type
        ' Only drawing files are to be saved with this code.
        If Not oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
            MsgBox("Bad document type selected")
            Exit Sub
        End If
        ' Check select set for item, if none is selected let user select.
        Dim oSelectSet As Inventor.SelectSet
        oSelectSet = oInvApp.ActiveDocument.SelectSet
        Dim oSelected_item As DrawingCurveSegment
        oSelected_item = Nothing
        If oSelectSet.Count <> 1 Then
            oSelected_item = Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter)
        ElseIf oSelectSet.Count = 1 Then
            oSelected_item = oSelectSet.Item(1)
        End If
        If oSelected_item Is Nothing Then
            MsgBox("Error, please try again.")
            Exit Sub
        End If
        Dim oDrawingCurve As DrawingCurve
        oDrawingCurve = oSelected_item.Parent
        Debug.Print("Selected curve type = " & oDrawingCurve.CurveType) ' Must be for circle 5124
        Debug.Print("Midpoint location = " & oDrawingCurve.CenterPoint.X & " - " & oDrawingCurve.CenterPoint.Y)
    End Sub
    Private WithEvents oInteraction As Inventor.InteractionEvents
    Private WithEvents oSelect As Inventor.SelectEvents
    Private oStillSelecting As Boolean
    Public Function Pick(filter As SelectionFilterEnum) As Object
        ' Initialize flag
        oStillSelecting = True
        ' Create a new interactionevent object
        oInteraction = oInvApp.CommandManager.CreateInteractionEvents
        ' Set the prompt
        oInteraction.StatusBarText = "Select an circle."
        ' Ensure the interaction is enabled
        oInteraction.InteractionDisabled = False
        ' Connect to the associated select events
        oSelect = oInteraction.SelectEvents
        ' Define that all circles should be selectable
        oSelect.AddSelectionFilter(filter)
        ' Enable single selection
        oSelect.SingleSelectEnabled = True
        ' Start the selection process
        oInteraction.Start()
        ' Loop untill a selection is made
        Do While oStillSelecting
            oInvApp.UserInterfaceManager.DoEvents()
        Loop
        ' Get the selected item
        Dim oSelectedEntity As ObjectsEnumerator
        oSelectedEntity = oSelect.SelectedEntities
        If oSelectedEntity.Count > 0 Then
            Pick = oSelectedEntity.Item(1)
        Else
            Pick = Nothing
        End If
        ' Stop the selection process
        oInteraction.Stop()
        ' Clean up.
        oSelect = Nothing
        oInteraction = Nothing
    End Function
    Private Sub Event_Terminates() Handles oInteraction.OnTerminate
        ' Set the flag to indicate we're done.
        oStillSelecting = False
    End Sub
    Private Sub Event_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View) Handles oSelect.OnSelect
    End Sub
I need the radius to I can determinate the position of my orientation text point
0° = (center point Y  + radius); center point X
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
