psaarloos
in reply to: psaarloos
I've found a solution by adding a reference to the AutoCAD Type Library from within Inventor VBA and accessing the ContainingDWGDocument object. Hoipefully it help somebody else with the same issue.
Pim
Dim odoc As DrawingDocument
Set odoc = ThisApplication.ActiveDocument
Dim acad As AcadDatabase
Set acad = odoc.ContainingDWGDocument
Dim removed As Boolean
On Error Resume Next
Dim acadObj As Object
For Each acadObj In acad.Dictionaries
    If TypeOf acadObj Is AcadDictionary Then
            If acadObj.Name = "ACAD_IMAGE_DICT" Then
                Dim acadImageDict As AcadDictionary
                Set acadImageDict = acadObj
                acadImageDict.Remove "<imagename>"
                removed = True
                Exit For
            End If
    End If
Next
On Error GoTo 0
If removed Then
    odoc.Update2
    odoc.Save
    ThisApplication.CommandManager.ControlDefinitions("VaultRefresh").Execute
End If
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
