rhasell
in reply to: LukeDavenport
Hi
I went though an exhaustive process with Curtis on this one. He wrote so much code trying to help me with this, which worked 99% of the time. The biggest issue was it was incredibly CPU intensive and killed my machine for up to 10 minutes while the code ran. (Thank to Curtis, this got me into iLogic)
At the end of the day, I found that creating a custom search in the assembly worked the best.  Save your various search filters and run them when you need them. Then its a simple RMB and toggle visibility. The only bug, is you cant select 'On' or 'Off' when some of the items are already toggled, so you may have to perform the process twice.
Reg
2025.2
