01-28-2016
09:34 AM
- Mute
- Permalink
- Report
01-28-2016
09:34 AM
Hi Lars,
1) Yes, that's the only way I'm aware of to do that
2) Brian checked it yesterday for another case and seems like it's not available through the API:
http://forums.autodesk.com/t5/inventor-answer-day/dataio-and-translators/m-p/6009816
3) The documentation for the xml format is in the sample xml file: "C:\Users\Public\Documents\Autodesk\Inventor 2016\Design Data\DWG-DXF\FlatPattern.xml"
Concernig the errors you are running into. Could you provide a minimal, non-confidential sheetmetal part file that could be used to reproduce the issue along with the ini file, etc you are using?
Cheers,
Adam Nagy
Autodesk Platform Services
