fakeru
354 Views, 2 Replies
Box.IsDisjoint Method
I'm trying to suppress with VBA all occurrences in assembly based on the condition if they intersect a part(cube:1).
I'm using rangeboxes for that and IsDisjoint methond. However nothing works as I expect.
Public Sub CutBox()
Dim AssDoc As AssemblyDocument
 Set AssDoc = ThisApplication.ActiveDocument
        Dim oAsmCompDef As Inventor.AssemblyComponentDefinition
        Set oAsmCompDef = AssDoc.ComponentDefinition
        Dim oOcc As ComponentOccurrence
        Dim CutBox As Box
       Set CutBox = AssDoc.ComponentDefinition.Occurrences.ItemByName("Cube:1").Definition.RangeBox
        For Each oOcc In oAsmCompDef.Occurrences
            If oOcc.Definition.RangeBox.IsDisjoint(CutBox) = True Then
                oOcc.Suppress
            End If
        Next
End Sub
Any idea what's wrong? I'm sure that some occurrences' rangebox do not intersect the cube's part range box, but Inventor doesn't suppress those occurrences.
Regards
Alexandru
Autodesk Inventor 2015 Certified Professional
