woodstylee3
in reply to: mikazakov
Hi, you appear to be trying to write to the active design project. I tend to find once files have been opened this is locked, and cannot be written to. It is also not always the file selected within the design project manager. Below is my code which is a bit messy but works, to get the currently selected project from the Context data passed with the button press..
Private Sub load_proj_options(Context As NameValueMap) Handles ss_OptButton.OnClick
 Dim x As Integer = 1
 Dim ds As String
 Dim dp As DesignProject = Nothing
 Do Until x = Context.Count
  If Context.Name(x) = "ProjectFileName" Then
     ds = Context.Item(x)
     x = x + 1
  End If
 Loop
 For Each design_project As Inventor.DesignProject In GlobalVars.m_inventorApplication.DesignProjectManager.DesignProjects
  If design_project.FullFileName = ds Then
     dp = design_project
  End If
 Next
 If Not (IsNothing(dp)) Then
   Dim n As New Proj_editor(dp)
      n.ShowDialog()
 End If
End Sub
