mikazakov
414 Views, 2 Replies
DesignProject return exception when properties try change.
I did new option button to Project's Dialog. But when I try change the Properties of ActiveDesignProject in sub of event sink, Inventor API return exception. Inventor API does not change the Properties of DesignProject until the Project's Dialog is opened.
But Content Center AddIn can do changes to DesignProject with open Project's Dialog. How Content Center AddIn does it?
Why do I fails it?
I attached two screenshots and vb.net sample code:
Imports Inventor
Imports System
Imports System.Runtime.InteropServices
Module Module1
    'Идентификатор кнопки
    Private OptButton As ProjectOptionsButton
    Private InvApp As Application
    Sub Main()
        InvApp = GetInventorApplication()
        Const ID As String = "123"
        OptButton = InvApp.DesignProjectManager.AddOptionsButton(ID, "MyButton", "Option")
        'Привязка делегата
        AddHandler OptButton.OnClick, AddressOf OnClick
        'Цикл обработки сообщений
        System.Windows.Forms.Application.Run()
    End Sub
    'Процедура приемник события
    Private Sub OnClick(Context As NameValueMap)
        Try
            InvApp.DesignProjectManager.ActiveDesignProject.OldVersionsToKeep = 5
        Catch ex As Exception
            Console.WriteLine(":(((((((")
        End Try
    End Sub
    'Функция получения ссылки на Inventor
    Function GetInventorApplication() As Application
        Dim InvApp As Application
        Try
            'Попытка присоединится к загруженному в память Inventor
            InvApp = CType(Marshal.GetActiveObject("Inventor.Application"), Application)
            'Загрузка Inventor в память и присоединение к нему
            Dim InvType As Type = Type.GetTypeFromProgID("Inventor.Application")
            InvApp = CType(Activator.CreateInstance(InvType), Application)
            InvApp.Visible = True
        End Try
        Return InvApp
    End Function
End Module
