Vladimir.Ananyev
in reply to: arge
Look at the following post:  Use iLogic to Change Base Quantity
http://forums.autodesk.com/t5/inventor-customization/use-ilogic-to-change-base-quantity/m-p/3222896/...
See Inventor API Help for the BOMQuantity.GetBaseQuantity method.  It allows to retrieve the base quantity for the part.  If the first argument is BOMQuantityTypeEnum.kParameterBOMQuantity then the second argument returns the parameter object.  You can get parameter name to use it in your rule.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
