in reply to: rjay75
yes I have used the PDF add in with the SaveCopyAs command... however, printing all sheets to our printer called PDFCreator allows us to merge all of the individual sheets into a single document.
The PDFCreator waits while the iLogic code opens and prints every part drawing. When the code is finished, it leaves open a PDF Creator window showing all the documents. We can select merge to make the separate documents into one document with multiple pages. It works well for our needs.
