rjay75
Here's a small iLogic Rule that will change the color of Faces as you select them.
SyntaxEditor Code Snippet
Public Sub Main()
Dim oFace As Face
'Copy the asset from the library to this document
Dim localAsset As Asset = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library").AppearanceAssets.Item("Bamboo").CopyTo(ThisDoc.Document, True)
'Keep Selecting Faces, Hit Esc to finish
Do
    oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Pick a feature")
    If Not oFace Is Nothing Then
        oFace.Appearance = localAsset
    End If
Loop While Not oFace Is Nothing
End Sub
