in reply to:
03:06 PM
- Mute
- Permalink
- Report
01-07-2016
03:06 PM
So I thought I would expand a little further in case someone in the future comes across this and wants to do something similar. Some of our drawings are on different size sheets (Letter, 11x17, ANSI D) so i'm reading the sheet size from each drawing file and converting that according to the PaperSize Enumerator from the programming help. The code isn't perfect - if anything in the "Try" section fails, it will say "File Not Found" even if it actually did find the file. But this is a very good start to what we need to accomplish.
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument Dim oDrawingView As DrawingView Dim oSheet As Sheet = oDrawDoc.ActiveSheet Dim oPartList As PartsList oPartList = oSheet.PartsLists(1) oDrgPrintMgr = oDrawDoc.PrintManager oDrgPrintMgr.Printer = "PDFCreator" oDrgPrintMgr.PrintRange = kPrintAllSheets oDrgPrintMgr.AllColorsAsBlack = False oDrgPrintMgr.ScaleMode = kPrintBestFitScale 'oDrgPrintMgr.ScaleMode = kPrintModel oDrgPrintMgr.ColorMode = kPrintDefaultColorMode oDrgPrintMgr.PaperSize = SizeActiveSheet oDrgPrintMgr.SubmitPrint Dim drawBomRow As DrawingBOMRow Dim refDoc As Document For Each oPartListRow In oPartList.PartsListRows If oPartListRow.Visible = "True" And oPartListRow.Custom = "False" Then Try drawBomRow = oPartListRow.ReferencedRows.Item(1) refDoc = drawBomRow.BOMRow.ComponentDefinitions.Item(1).Document FilePath = refDoc.FullFileName() FilePath = Left(FilePath,Len(FilePath)-3) & "idw" ThisApplication.Documents.Open(FilePath,True) Dim oDrawDoc2 As DrawingDocument = ThisApplication.ActiveDocument 'use PaperSizeEnum from inventor programming help PageSize = oDrawDoc2.ActiveSheet.Size If PageSize = 9990 Then PageSize = 14347 End If If PageSize = 9987 Then PageSize = 14353 End If If PageSize = 9988 Then PageSize = 14338 End If oDrgPrintMgr2 = oDrawDoc2.PrintManager oDrgPrintMgr2.Printer = "PDFCreator" oDrgPrintMgr2.PrintRange = kPrintAllSheets oDrgPrintMgr2.AllColorsAsBlack = False oDrgPrintMgr2.ScaleMode = kPrintBestFitScale 'oDrgPrintMgr.ScaleMode = kPrintModel oDrgPrintMgr2.ColorMode = kPrintDefaultColorMode oDrgPrintMgr2.PaperSize = PageSize oDrgPrintMgr2.SubmitPrint ThisApplication.ActiveDocument.Close(True) Catch drawBomRow = oPartListRow.ReferencedRows.Item(1) refDoc = drawBomRow.BOMRow.ComponentDefinitions.Item(1).Document FilePath = refDoc.FullFileName() FilePath = Left(FilePath,Len(FilePath)-3) & "idw" MessageBox.Show(FilePath, "File Not Found") End Try End If Next
