12-08-2015
05:03 PM
- Mute
- Permalink
- Report
12-08-2015
05:03 PM
The label ID that will be used in the next view is not exposed through the API and neither is any functionality to create a view label independent of actually creating a view. However, I went ahead and wrote a little VBA function that takes an existing view label as input and returns the next view label. For example if I pass in "A" it will return "B". It skips the letters not allowed in the ISO standard and will begin outputting double letters when it reaches the end of the alphabet. For example, if I pass in "Y" it will return "AA" since "Z" is skipped. The important function is GetNextLabel and TestViewLabel is just for testing.
Public Sub TestViewLabel()
Dim i As Integer
For i = 1 To 50
Dim lbl As String
Dim oldLabel As String
oldLabel = lbl
lbl = GetNextLabel(lbl)
Debug.Print oldLabel & " = " & lbl
Next
End Sub
Public Function GetNextLabel(Optional ByVal ExistingLabel As String = "") As String
If ExistingLabel = "" Then
GetNextLabel = "A"
Else
ExistingLabel = UCase(Trim(ExistingLabel))
Dim charCount As Integer
charCount = Len(ExistingLabel)
Dim charString As String
charString = Mid(ExistingLabel, 1, 1)
Dim charCode As Integer
charCode = Asc(charString)
Select Case charString
Case "H", "N", "P", "R", "W"
' Special case for characters before I, O, Q, S, and X. Increment
' by two in those cases to skip those letters which aren't to be
' in the ISO standard.
charCode = charCode + 2
Case "Y"
' Special case for the character before Z, so that it will start
' over at A but have an additional character.
charCode = 65
charCount = charCount + 1
Case Else
charCode = charCode + 1
End Select
' Build the label string.
Dim labelChar As String
labelChar = Chr(charCode)
GetNextLabel = String(charCount, labelChar)
End If
End Function
