- Mute
- Permalink
- Report
Remove Constraints and ground components within subassembly
I am trying to remove all constraints, and ground all components within a subassembly.
I am replacing components within a subassembly. But to make this easy, and without iMates, I have to remove all constraints, and ground all components within that subassembly.
I tried these two codes:
SyntaxEditor Code Snippet
'start of ilogic code' get the active assembly Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition 'set the Master LOD active Dim oLODRep As LevelofDetailRepresentation oLODRep = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Master") oLODRep.Activate 'Iterate through all of the occurrences and ground them. Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences 'check for and skip virtual components If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then oOccurrence.Grounded = True Else End If
Dim oAssDoc As AssemblyDocument oAssDoc = ThisApplication.ActiveDocument Dim oConstraint As AssemblyConstraint i = 0 For Each oConstraint In oAssDoc.ComponentDefinition.Constraints oConstraint.Delete i = i + 1 Next MessageBox.Show(" A total of "& i & " constraints were deleted.", "iLogic")
These work perfect in an assembly, but they do nothing to subassemblies.
I even tried to put them inside the subassembly and running it within the subassembly by using an external rule. But this also doesn't work.
If I try this I will get these errors:
Constraints;
It doesn't give an error, but it just doesn't remove any constraints.
I will get the message: A total of 0 constraints were deleted.
Grounden;
Error in rule: Grounden, in document: subassembly.iam
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
If I open the subassembly, and run the rules there everything works fine again.
I hope someone can help me out!
Melle Oosterman
Inventor Autodesk Inventor 2014
- Mute
- Permalink
- Report
Melle. I cant reproduce the code required without doing the work needed but the process would be something like this.
I would move the constraint deleting and grounding to its own sub where i would pass in the assembly you want it applied to.
For each component occurence you need to check if typeof is kassemblycomponentdefinition then pass this into the sub. This could be a bit complicated so another way might be this;
Instead of using the bom you should navigate something like
Dim odoc as inventor.assemblydocument: set odoc = thisapplication.activedocument.
Dim oChildDoc as inventor.document.
For each oChildDoc in odoc.allreferencedfiles
if ochildDoc.componentdefinition.type = assembly then
pass to sub (ochilddoc)
end if
next
Then at the end pass in odoc.
Also you might need to add in a check for the windows file state 'ReadOnly' and change it before editing. Assuming you are allowed to edit all these files.
PPS i would also do it in VBA as its much easier to bug test/step through. And you can navigate the API.
Inventor 2010 Certified Professional
Currently using 2023 Pro
