Owner2229
Hi, I don't know where the problem is, as the rule is runing correctly for me. The line seems to be fine.
Try to copy it from the attached text file instead.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
