Owner2229
Hi, aren't you trying to create new part using your template? For it works the code below:
Dim g_App As Inventor.InventorServer = ThisApplication
Dim oNewPart As AssemblyDocument
oNewPart = g_App.Documents.Add(DocumentTypeEnum.kPartDocumentObject, , True)
Else use the folowing: (False to open it invisibly)
oApp = Marshal.GetActiveObject("Inventor.Application")
oDocs = oApp.Documents
oDoc = oDocs.Open("C:\Template.ipt", False)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
