11-11-2015
10:11 PM
- Mute
- Permalink
- Report
11-11-2015
10:11 PM
Hi, this rule below should meet your needs.
1) It will ask for Stock Numbers. Write in e.g.: RUCW001;RUCW002;RUCW003
(I can change it to use the Excel table or text file if you want)
2) Then it will create new assembly for each specifed Stock Number. But it won't save it (I can change it for you, if you want).
3) And then it will look for parts with matching Stock number and add them to these assemblies.
Sub Main()
Dim g_App As Inventor.InventorServer = ThisApplication
Dim oDoc As Document = ThisApplication.ActiveDocument
If Not oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("This rule is for assembly only.")
Exit Sub
End If
Dim OrigASM As String = ThisDoc.PathAndFileName(True)
Dim oPath As String = ThisDoc.Path & "\"
'SearchedPartExample = "RUCW001;RUCW002;RUCW003"
SearchedPart = InputBox("Please insert stock number of searched parts", "Input")
If SearchedPart = vbNullString Then
Exit Sub
End If
'specify word splitting character ";"
Dim Separators() As Char = {";"c}
oStockNumbers = SearchedPart.Split(Separators)
i = 0
For Each oStockNR In oStockNumbers
Dim oNewAsmDoc(i) As AssemblyDocument
oNewAsmDoc(i) = g_App.Documents.Add(DocumentTypeEnum.kAssemblyDocumentObject, , True)
Call LookForStockNR(oDoc, oStockNumbers(i), oNewAsmDoc(i))
i += 1
Next
oDoc.Activate
End Sub
Sub LookForStockNR(oDoc As Document, oStockNR As String, oNewDoc As AssemblyDocument)
Dim refDocs As DocumentsEnumerator = oDoc.AllReferencedDocuments
Dim refDoc As Document
For Each refDoc in refDocs
ModelFileName = refDoc.FullFileName
FNamePos = InStrRev(ModelFileName, "\", - 1)
docFName = Mid(ModelFileName, FNamePos + 1, Len(ModelFileName) - FNamePos)
If iProperties.Value(docFName, "Project", "Stock Number") = oStockNR Then
Call AddOccurrence(oNewDoc, ModelFileName)
End If
Next
End Sub
Sub AddOccurrence(oNewDoc As AssemblyDocument, oPartToAdd As String)
Dim oAsmCompDef As AssemblyComponentDefinition = oNewDoc.ComponentDefinition
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oMatrix As Matrix = oTG.CreateMatrix
Call oMatrix.SetToRotation(3.14159265358979 / 4, _
oTG.CreateVector(0, 0, 1), oTG.CreatePoint(0, 0, 0))
Call oMatrix.SetTranslation(oTG.CreateVector(3, 2, 1))
Dim oOcc As ComponentOccurrence
oOcc = oAsmCompDef.Occurrences.Add(oPartToAdd, oMatrix)
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Mike
