Owner2229
Hi, I believe we can adjust the rule to your need, I just need some info:
1) What is the extension of your parts (or extensions, if you have more than one).
2) Can you add all parts starting with "RUCW" or you need to type in the whole number?
3) Do you want to add subassemblies or parts only?
4) Can you use manual "Save As" to save the assembly or you want it to automaticaly pop up the "Save As" dialog at the end of the rule?
5) Do you want to add parts from pre-specifed folder or you want to choose the folder on each run of the rule or you want to pick the parts from some kind of part list (Excel table, TXT, etc.) or from another assembly?
You don't need to have open blank assembly, any assembly would work.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
