in reply to: Vladimir.Ananyev
This ran and showed a comment box that the parameter was updated. My custom iproperty I had named as Weight, so I changed everything in the iLogic that was "AAA" to "Weight." I then created a user text parameter "Weight." Ran the rule. Message box says  "Parameter was updated: 335.08 lbs." When I check the parameter I created, it is blank. What parameter is updated, and where do I find it?
