11-05-2015
10:56 PM
- Mute
- Permalink
- Report
11-05-2015
10:56 PM
You can use this to add ALL parts from one directory selected by prefix to your currently opened assembly:
Imports System.IO
Imports System.IO.File
Sub Main
Dim oDoc As Document = ThisApplication.ActiveDocument
If Not oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
MsgBox("This rule is for assembly only.")
Exit Sub
End If
'You can change this line to match your location if you have all files in one folder
'Otherwise it will be used as initial folder for folder search
oPath = "C:\FolderContainingAllParts"
'Or you can use this to select the folder, delete it if not needed
Dim dialog1 = New System.Windows.Forms.FolderBrowserDialog()
dialog1.SelectedPath = oPath
dialog1.ShowNewFolderButton = True
If System.Windows.Forms.DialogResult.OK = dialog1.ShowDialog() Then
oPath = dialog1.SelectedPath
Else
MsgBox("No folder selected. Copiyng canceled.")
Exit Sub
End If
If Not System.IO.Directory.Exists(oPath) Then
MsgBox("Folder doesn't exist")
End If
SearchedPart = InputBox("Please insert prefix of searched parts", "Prefix", DXFName)
If SearchedPart = vbNullString Then
Exit Sub
End If
Dim oFile As String
'It will only look for parts, as there is "*.ipt" at the end
For Each oFile In System.IO.Directory.EnumerateFiles(oPath, SearchedPart & "*.ipt")
AddOccurrence(oFile)
Next
End Sub
Public Sub AddOccurrence(oPartToAdd As String)
Dim oAsmCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oMatrix As Matrix = oTG.CreateMatrix
Call oMatrix.SetToRotation(3.14159265358979 / 4, _
oTG.CreateVector(0, 0, 1), oTG.CreatePoint(0, 0, 0))
Call oMatrix.SetTranslation(oTG.CreateVector(3, 2, 1))
Dim oOcc As ComponentOccurrence
oOcc = oAsmCompDef.Occurrences.Add(oPartToAdd, oMatrix)
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Mike
