4820 Views, 6 Replies
link a new parameter to a custom iproperty
In an assembly drawing, I am wanting to pull information from various subassemblies to show as information in a text box. I can get the information to populate in a custom iProperty, & noticed that the text block can pull from parameters in subassemblies & parts. Is there a way to link a user parameter to the custom iproperty?
Nathan
BrandonBG
in reply to: BrandonBG
The opposite direction, instead of parameter to iProperty, I need iProperty to parameter.
Vladimir.Ananyev
You may consider the following simple iLogic rule.
It reads the custom property "AAA" value and then assigns it to the user-defined text parameter “Parameter_AAA”:
' iLogic rule 'UpdateUserParameter'
' reads custom property "AAA" value Dim PropValue As String = iProperties.Value("Custom", "AAA") 'updates the user-defined text parameter Parameter_AAA = PropValue   'this message is for debugging only MsgBox("Parameter was updated: " & Parameter_AAA)
Using iLogic event you may handle iProperty changes automatically:
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
in reply to: Vladimir.Ananyev
This ran and showed a comment box that the parameter was updated. My custom iproperty I had named as Weight, so I changed everything in the iLogic that was "AAA" to "Weight." I then created a user text parameter "Weight." Ran the rule. Message box says  "Parameter was updated: 335.08 lbs." When I check the parameter I created, it is blank. What parameter is updated, and where do I find it?
Vladimir.Ananyev
 I expect your updated rule  looks like this:
Weight = PropValue
MsgBox("Parameter was updated: " & Weight)
Name in blue should be the name of your user parameter.
Vladimir Ananyev
I believe this works. Awesome! Thank you for the help & the code.
