- Mute
- Permalink
- Report
This code will partially do what you want, based upon the assumption that the browser nodes in your assembly are the same as the part number (which they usually are by default):
If you can create a simple vba userform with a textbox and button within the VBA editor, then insert this code into the button click action.
This code will look through all levels of the assembly and DELETES ALL the components it comes across that DO NOT MATCH what was typed into the textbox. So I would advise saving or creating a copy of the assembly you want to purge before doing anything further.
hopefully this will be of some use to you, or at least give you a starting point as I haven't had a huge amount of time to debug this thoroughly.
Private Sub CommandButton1_Click()
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
' Get the assembly component definition.
Dim oAsmDef As AssemblyComponentDefinition
Set oAsmDef = oAsmDoc.ComponentDefinition
' Get all of the leaf occurrences of the assembly.
Dim oLeafOccs As ComponentOccurrencesEnumerator
Set oLeafOccs = oAsmDef.Occurrences.AllLeafOccurrences
' Iterate through the occurrences and print the name.
Dim oOcc As ComponentOccurrence
For Each oOcc In oLeafOccs
'Delete the parts that don't match
Dim oName As String
Dim strOrig As String
Dim Ref1 As String
Dim L As Integer
strOrig = oOcc.name
Ref1 = Left(strOrig, InStr(strOrig, ":"))
L = Len(Ref1) - 1
If Ref1 <> TextBox1.Text & ":" Then
oOcc.Delete
End If
Next
End Sub
