820 Views, 2 Replies
Open an ipt from iam using ilogic
Hello all,
Is it possible to open a part from within an open assembly using ilogic? I have a master assembly that when opened notifies the designer that a "Save As" is to be perform and when the message box is closed the "Save As" file dialog box opens to allow the designer to enter the new assembly number and then click save. What I would like to happen is once the file dialog box closes after the save button is clicked, a specified part within the new assembly is opened in a new window, same as going to the part within the assembly and "right click open".
Scott
